Remove soil layer
thanh2611
Remove soil layer
Post by thanh2611 » Fri Feb 14, 2020 2:56 am
My name is Thanh. I am trying to replicate this example in STKO. https://opensees.berkeley.edu/wiki/inde ... _Pile_Wall.
My question is how can I remove the soil layers like in this example.
Thank you so much
Re: Remove soil layer
Post by STKO Team » Sat Feb 15, 2020 8:47 am
Dear Thanh,
Now you can remove elements as they did in the official opensees example, i.e. by element ID (this can be done in STKO using a custom script). However this is neither efficient nor general, and requires a good knowledge of TCL.
We are currently implementing a feature (a new AnalysisStep call "removeSubset") that will let you remove a subset of a geometry using different rules:
  • Plain (the entire selectionSet will be removed when you issue the command)
  • FunctionOfTimeAndSpace (elements and nodes will be removed as function of their spatial coordinate and time)
  • FunctionOfElementResult
  • FunctionOfNodalResult
This will be ready by the next week. I will inform you here when the new update will be available
thanh2611
Post by thanh2611 » Mon Feb 17, 2020 1:16 am
Thank you so much
thanh2611
Post by thanh2611 » Mon Feb 17, 2020 1:36 am
I only knew to add tcl script to STKO in the analysis step. Therefore, I want to ask which feature can I implement tcl script in?
Post by STKO Team » Tue Feb 18, 2020 3:14 pm
Dear than,
As I said, at the moment you can do it via the CustomCommand (TCL Script).
Attached you can find a (zipped) SCD file where I use the TCL custom command to remove elements and nodes as a function of space and time.
However there are some subtle issues with this approach (that's why we are implementing it in a more robust way directly inside the Python interface of STKO):
  • the UMFPack solver does not work when you remove objects (I used the SuperLU for this)
  • If you use the Penalty method, you need to remove all sp and mp constraints for every node that you remove (see my scripts)
  • You cannot apply point loads on nodes that will be removed
Have a look at this sample file and let me know if everything is clear.
remove.zip
(88.96 KiB) Downloaded 317 times
thanh2611
Post by thanh2611 » Thu Feb 20, 2020 6:54 am
Thank you so much
