I have a question:
In this website:
and In this website:
Then my question is: if absorbingboundary is adopted, are the output velocity, acceleration, displacement and other results absolute or relative?
Looking forward to your reply, thank you!!!
If you want to understand how a wave travels from bottom to top, you should do it with a simpler input. In such a way that the input is done before the wave gets reflected from the top free surface.Because I only need to use the acceleration data of the bottom and the top when the seismic wave first travels from the bottom to the top to calculate the transfer function. So how do I extract data without considering seismic reflection?
Ok!My research is focus on the wave propagate in the soil considering the SSI.
You can simply record the acceleration on top and compare it with the input acceleration obtained taking derivatives of your velocity time series (not the one recorded at the base)Anyway, you don't need to record the acceleration at the bottom. If you only want the input you already have it (a derivative of velocity)
