absorbing boundary
spater
Re: absorbing boundary
Post by spater » Thu Dec 30, 2021 1:09 am
Thank you very much!
I have a question:
In this website:
屏幕截图 2021-12-30 090023.png (28.61 KiB) Viewed 3198 times
and In this website:
屏幕截图 2021-12-30 090519.png (54.3 KiB) Viewed 3198 times
Then my question is: if absorbingboundary is adopted, are the output velocity, acceleration, displacement and other results absolute or relative?
Looking forward to your reply, thank you!!!
Post by STKO Team » Thu Dec 30, 2021 9:20 am
Only the UniformExcitation generates relative outputs, because its keeps the base fixed, so your model will move relatively to the fixed base.
The MultiSupportExcitation instead generates absolute results, in fact you will see that the base moves as well.
When you use the absorbing boundary elements, you input a velocity field, and the absorbing element transforms it into a boundary traction (forces). So the output will be absolute as well.
spater
Post by spater » Thu Dec 30, 2021 11:45 am
What if I want to know what the acceleration at the bottom is? Do I get the acceleration at the bottom directly by adding the velocity integral to the input or do I get the acceleration at the bottom from the calculation? Because I realized that the acceleration that I got by integrating the input velocity is not the same as the bottom acceleration that I got from the calculation.
Post by STKO Team » Thu Dec 30, 2021 5:17 pm
The acceleration recorded at the bottom part of the soil (nodes shared between the soil and the bottom absorbing boundaries) should be exactly equal to the derivative of velocity with respect to time, not the integral...
Of course it is true if you set the material parameters of the absorbing layer properly, so that they match the material parameters of the soil
spater
Post by spater » Fri Dec 31, 2021 12:41 am
I'm sorry, but acceleration should be given by taking a derivative with respect to velocity. My speed is only applied in the X direction. I extracted the acceleration in the X direction of a certain point at the bottom by STKO calculation, which is inconsistent with the acceleration obtained by taking the derivative of the input speed. In my model, the parameters of my sendboundary are exactly the same as those of my soil. May I ask how to solve this problem? Attached is my model. Could you please help me check what is the problem? Thank you very much.
simple_model.rar
(186.87 KiB) Downloaded 185 times
Post by STKO Team » Mon Jan 03, 2022 3:07 pm
I took the derivative of your velocity with respect to time to obtain the acceleration, and I put it as a background in your monitor at the base so that you can compare the numerical solution.
You will notice that at the beginning they match pretty well, while later on, you will see a slight difference. This happens because what you record at the bottom is both the input waves moving up and the waves reflected from the top surface going down.
It makes perfect sense.
onelayer_without-box.zip
(408.5 KiB) Downloaded 239 times
spater
Post by spater » Tue Jan 04, 2022 6:40 am
Thank you for replying!!!
Because I only need to use the acceleration data of the bottom and the top when the seismic wave first travels from the bottom to the top to calculate the transfer function. So how do I extract data without considering seismic reflection?
Post by STKO Team » Tue Jan 04, 2022 9:21 am
If you want to understand how a wave travels from bottom to top, you should do it with a simpler input. In such a way that the input is done before the wave gets reflected from the top free surface.
The problem with a long ground motion is that when the wave travels back to the bottom, the input is still creating new waves going in...
Try with a simple pulse or ricker wavelet as I did in our webinar.
Anyway, you don't need to record the acceleration at the bottom. If you only want the input you already have it (derivative of velocity)
spater
Post by spater » Tue Jan 04, 2022 1:20 pm
My research is focus on the wave propagate in the soil considering the SSI.
Post by STKO Team » Tue Jan 04, 2022 5:11 pm
Ok!
As I said here:
Anyway, you don't need to record the acceleration at the bottom. If you only want the input you already have it (a derivative of velocity)
You can simply record the acceleration on top and compare it with the input acceleration obtained taking derivatives of your velocity time series (not the one recorded at the base)
