hi STKO team,
I wanted to ask you what the m1 parameter (Shear-Compression reduction factor) was in the Damage TC3D material? What is the influence of m1 on the behavior of the material?
Thanks a lot for your availability.
Pasquale
m1 Shear-Compression reduction factor- DAMAGE TC3D
- Screenshot DAMAGE TC3D-m1.png (108.44 KiB) Viewed 2000 times
Re: m1 Shear-Compression reduction factor- DAMAGE TC3D
Check our publication on this material:
https://www.researchgate.net/publicatio ... hear_walls
In chapter 4. Shear behavior and dilatancy of the Tension/Compression ContinuumDamage Model, the value (called k1 at that time) is described
