Hello STKO team,
I have been working on an analysis of a building representing the 1976 UBC. I have had success with using P-delta, when I change the transfer type for the elastic-beam element property. When I try to change it to corotational, I have the following error:
Modified Ibarra-Medina-Krawinkler Model with Peak-Oriented Hysteretic Response
CorotCrdTransf3d::CorotCrdTransf3d: rigid joint zones not implemented yet
Using zero values
Using zero values
I am not sure what this error means, could you help me diagnose this issue? I have attached a copy of my model
Many thanks,
Kate
Corotational with Elastic Beam Column Elements
Kate_Rhoades
- 1976_nonlinear_model.zip
- (2 MiB) Downloaded 250 times
Re: Corotational with Elastic Beam Column Elements
Hi, this message appears because the rigid joint offset option for Corotational geometric transformation is not implemented in 3D case.
Kate_Rhoades
Ah, Ok, so for my 3D modeling I should stick to using P-delta or linear? Corotational can only be used in 2D modeling?
It is better to use P-Delta if the drift is significant because the second-order effect can influence the bending moments in structural members.Ah, Ok, so for my 3D modeling I should stick to using P-delta or linear?
Yes, if you use any rigid joint offsets.Corotational can work only in 2D modeling?
Kate_Rhoades
Ok! Thank you for explaining this, I really appreciate it!
You are welcome
