Dear STKO,
I am currently trying to export nodal displacement time history to a text file.
I am able to do so by going over the displacement at each time step following the Python API tutorials provided.
My question is:
Is it possible to access the entire displacement time-history for a single node at once?
I have over 9000 time-steps and 30 nodes, therefore going step by step in a 'for loop' becomes a very lengthy process
I have attached my code for reference.
Thank you for your help.
Export Nodal results time history via Python API
- Extract_Nodal_Results.zip
- (1.79 KiB) Downloaded 243 times
Re: Export Nodal results time history via Python API
Try this:
I fixed an error in the indexing. The step_id is not necessarily 1-based (it depends on how many stages you have).
I used the zip command to iterate over the step_id and the step_time at the same time:
To speed up the process I made a reduced mesh containing only the nodes you need to extract.
It will reduce the size of the dataset of each evaluation:
Let me know the speed-up you get. I tried it on a small model and it already gave a 20x speed-up
for step_id, step_time in zip(all_steps, all_times): #Loop for timesepIt will reduce the size of the dataset of each evaluation:
# make a fake mesh with only the required nodes
# 1. do a first evaluation to get the real mesh
# 2. from the real mesh get the requested nodes and copy them into the reduced mesh
# 3. save the reduced mesh in the evaluation options
opt.step = all_steps[0]
field = Disp.evaluate(opt)
reduced_mesh = MpcMesh()
for i in NODES:
inode = field.mesh.getNode(i)
reduced_mesh.addNode(inode)
opt.mesh = reduced_mesh
Reducing the mesh for each evaluation worked perfectly!
It was able to speed up the process by 20x
Andres R
Andres R
You're welcome. And the speed up will be greater as the ratio total_number_of_nodes/required_number_of_nodes increases (i.e. for large models the speed up is larger)
