I encountered another error:
when I add "E" and "Ep_mod" of Elastic Membrane Shell Section to parameter and want to update them. In my local computer, it can run without any warning using openseesMp, and it says that they were updated successfully.
However, when I tried to run it on supercomputer (TACC's frontera https://www.tacc.utexas.edu/systems/frontera ). It popped out the error that these two parameters cannot be added to parameter object. I am curious why. I am using the openseesmp from prof. Nicola Tarque, Pontifical Catholic University of Peru. The version is 3.4.0 64-Bit. On the supercomputer environment (https://opensees.berkeley.edu/OpenSees/ ... rallel.php), the version is 3.3.0 64-Bit. I am suspicious it is due to the version difference. Could you please have a look at my model and opensees source code of these two versions at your best convenience? I tried to understand where the problem is, but I cannot due to my limited knowledge of c++ language.
Ele: 3385 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Parameter::addComponent 4 -- no objects were able to identify parameter
Ep_mod
Ele: 3386 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3387 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3388 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3389 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3390 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3391 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3392 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3393 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3394 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3395 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3396 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3397 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3398 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3399 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3400 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3401 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3402 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3403 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3404 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3405 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3406 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3407 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3408 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3409 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3410 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3411 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3412 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3413 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3414 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3415 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3416 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3417 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3418 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3419 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3420 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3421 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3422 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3423 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3424 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3425 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3426 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3427 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3428 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3429 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3430 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3431 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3432 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3433 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3434 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3435 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3436 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3437 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3438 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3439 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3440 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3441 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3442 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3443 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3444 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3445 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3446 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3447 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3448 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3449 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3450 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3451 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3452 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3453 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3454 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3455 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3456 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3457 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3458 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3459 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3460 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3461 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3462 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3463 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3464 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3465 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3466 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3467 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3468 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3469 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3470 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3471 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3472 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3473 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3474 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3475 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Ep_mod
Ele: 3476 - Ep_mod = 1.00000000000000000000 -> 0.6666666666666666
Using ASDShellQ4 - Developed by: Massimo Petracca, Guido Camata, ASDEA Software Technology
Using ASDEmbeddedNodeElement - Developed by: Massimo Petracca, Guido Camata, ASDEA Software Technology
PID: 4 - OLD_SIZE = 1908; NEW_SIZE = 360 (col)
PID : 4 - OLD_SIZE = 1900; NEW_SIZE = 0 (wall)
PID: 5 - OLD_SIZE = 1908; NEW_SIZE = 475 (col)
PID : 5 - OLD_SIZE = 1900; NEW_SIZE = 0 (wall)
PID: 2 - OLD_SIZE = 1908; NEW_SIZE = 265 (col)
PID : 2 - OLD_SIZE = 1900; NEW_SIZE = 0 (wall)
PID: 1 - OLD_SIZE = 1908; NEW_SIZE = 308 (col)
PID : 1 - OLD_SIZE = 1900; NEW_SIZE = 0 (wall)
