Does self-weight still need to be considered when calculating load after adding mass?
w1289521589
Post by w1289521589 » Sat May 28, 2022 2:16 am
Dear Sir/Madam, I am currently doing a dynamic analysis of a structure and I added mass to the structure through edgemass and facemass when I built the model. So when I need to calculate the load of the structure, do I need to consider the self-weight of the member? Thank you.
Re: Does self-weight still need to be considered when calculating load after adding mass?
Post by STKO Team » Mon May 30, 2022 10:37 am
You need to define both mass and weight (as a load). This is necessary because you do not actually model the gravity acceleration (0, 0, -9.8 m/s^2). Instead, you typically do a static analysis, so the effect of mass*gravity should be done with loads
