Property
w1289521589
Property
Post by w1289521589 » Fri Apr 15, 2022 7:57 am
Could you please tell me how to use ZeroLengthSection Element in STKO? I hope to use it to simulate the bond slip of rebar. I hope those who know how to use it can give me some guidance or suggestions. Thank you very much
Lucy2012
Re: Property
Post by Lucy2012 » Sat Apr 16, 2022 6:14 pm
Please check our manual and the forum using search.
In addition please watch our training courses:
https://asdeasoft.net/?stkowebinars-for-opensees
Nr. 7 of the advanced and nr. 14 of the getting started explains you how to model zero length.
Re: Property
Post by STKO Team » Tue Apr 19, 2022 7:46 am
As Lucy said, you can watch these webinars to understand how to use interactions to model zero-length elements.
The modeling procedure is exactly the same for ZeroLengthSection.
The only differences are:
  • You need to assign a Section (either elastic or fiber) as a Physical Property
  • You need to define a local axes which has the local X direction perpendicular to the section plane
