Definitions
[email protected]
Definitions
Post by [email protected] » Mon Mar 28, 2022 11:42 am
The rotate and displacement need to be added on the top of the model in hysteresis loading. This is that they have the same time series Image. However, they have different loading method(time series in definitions). If rotate and displacement have to be added at same time , how to do the set? This is the scd model file
220328.zip
(182.43 KiB) Downloaded 141 times
, and you can do the revise.
Re: Definitions
Post by STKO Team » Tue Apr 05, 2022 2:12 pm
If the displacement and rotation have different loading histories you can simply create 2 timeSeries and 2 loadPatterns.
the first load pattern will have the timeSeries for displacement and the imposed displacement under "sp"
the second load pattern will have the timeSeries for rotation and the imposed rotation under "sp"
