MPCO recorder in OpenSees 3.3.0
nicola.c
Post by nicola.c » Fri Feb 25, 2022 11:58 am
Dear STKO community,
I'm working with my model in OpenSees and I'm trying to generate an mpco recorder to be used with STKO post-processor. As long as I was using version 3.2.2 of OpenSees I had no problem, but since I switched to the version 3.3.0 I am no longer able to generate mpco recorders obtaining the following error after running the analysis (that is blocked):
commands.cpp - : mpco NOT FOUND
WARNING No recorder type exists for recorder of type:mpco-1
Is there anyone who can help me?
Horace Horsecollar
Re: MPCO recorder in OpenSees 3.3.0
Post by Horace Horsecollar » Fri Feb 25, 2022 3:31 pm
Unfortunately, the MPCO recorder does not work on 3.3.0. You can either use:
1) an older version, HDF5 database was implemented in the 3.0.0
2) prof. Tarque's version: https://drive.google.com/file/d/1ETGQ3Y ... 5Mk7C/view
Bear in mind that the next official version of OpenSees will support the MPCO and HDF5 database.
nicola.c
Post by nicola.c » Sat Feb 26, 2022 3:25 pm
So we just have to wait for the new version.
Thank you for your fast and accurate reply.
Kind regards,
Nicola
Horace Horsecollar
Post by Horace Horsecollar » Sat Feb 26, 2022 3:48 pm
As we said meanwhile you can use prof. Tarque's version which is 3.3.0.
M Ilyas
Post by M Ilyas » Thu Jun 23, 2022 7:49 pm
The MPCO recorder issue persists even after I have tried prof. Tarque's version of solver kit with STKO versions 2.0.6 and 3.0.0. kindly help!!!
Post by STKO Team » Fri Jun 24, 2022 9:40 am
It's strange.. it should be there. could you show the error you have?
