Why I cannot see the pile?
spater
Post by spater » Mon Dec 13, 2021 3:48 am
I built the model step by step from your webinar video, but when I finished the analysis, I loaded the results, I only could see the line represented the pile. I assigned the section to the pile. What should I set in the postprocessor?
[email protected]
Re: Why I cannot see the pile?
Post by [email protected] » Mon Dec 13, 2021 4:57 am
Make sure "show beam extrusion" is turned on in the surface plot options.
spater
Post by spater » Mon Dec 13, 2021 6:53 am
I turned it on but it still invisible.
Post by STKO Team » Mon Dec 13, 2021 8:38 am
If you created the model from the STKO pre-processor, and you used an MPCRecorder analysis step (not manually via TCL scripting" you should have a file with the same name of your mpco recorder, but with the mpco.cdata extension.
Can you verify you have it? otherwise the beam extrusion won't be visible.
spater
Post by spater » Mon Dec 13, 2021 9:25 am
I downloaded this model from THE STKO website, I want to see the post processing module, but it just can't show the pile.
Can you help me to solve this problem?
It confused me very much.
Thank you!
T05_soil_pile_test.rar
(186.37 KiB) Downloaded 205 times
Post by STKO Team » Mon Dec 13, 2021 11:16 am
I know. Do you have the .mpco.cdata (the highlighted one) file in your directory?
Immagine 2021-12-13 121523.png (53.26 KiB) Viewed 3878 times
spater
Post by spater » Mon Dec 13, 2021 12:49 pm
I don't have this file.
I found the description of the ".mpco.cdata" file in the STKO manual. But when I finished analysis, it didn't creat this file.
How can I deal with this problem?
Thank you very much.
Best reagrd!
spater
Post by spater » Wed Dec 15, 2021 2:20 am
can you help me solve this problem? I really need to solve this problem
I hope you can reply to me as soon as possible. Thank you very much.
Post by STKO Team » Wed Dec 15, 2021 8:53 am
Unfortunately, the file you attached is perfectly working on our side.
Are you sure you did not change anything in the file?
Can you show a screenshot of what files you have in the folder?
spater
Post by spater » Wed Dec 15, 2021 9:20 am
I re-downloaded the file from the official website without making any changes, but it is still the same.
Eventhouht there exised a ***.mpco.cdata file, I still can only see one thread.
Attached is my operation screen recording, please help me solve this problem, I am really anxious.
Thank you very much!
screenshot.rar
(17.68 MiB) Downloaded 209 times
