I want to analysis the time history model of the webinar(week16 ex25.scd)using openseesmp, but I don't know how to change the setting.
It's not solved just by using mumps and dividing partitions, but I don't know how.
Is there a summary of how to use openseesmp?
I'm sorry, but can you make an example file with the ex25.scd that has been changed to use the openseesmp?
Where can I check the setting method related to openseesmp?
- ex25.zip
- (314.97 KiB) Downloaded 124 times
Re: Where can I check the setting method related to openseesmp?
Dear gokki,
you need to change the numberer too, picking Parallel RCM Numberer and then choose the openseesmp solver in the analysis tab.
Beware that the eigen analysis will not run, it is not possible to run the eigen command in parallel in OpenSees.
Enjoy your modelling
