P-M Interaction Diagram for Column
ankurjain1992
Post by ankurjain1992 » Mon Aug 03, 2020 5:43 pm
How can we draw a P-M Interaction Diagram for Column Fiber Section in STKO.
Clarabella
Re: P-M Interaction Diagram for Column
Post by Clarabella » Tue Aug 04, 2020 1:22 pm
Dear ankurjain1,
we are implementing an automatic tool in python to draw the P-M interaction diagram, we will release it next fall. Meanwhile, you can draw it manually. You just have to model a section, apply first the vertical load (P) and then a horizontal load or displacement to calculate M. Change the value of P to obtain the P-M diagram and if you like also the angle of application of the horizontal load or displacement to obtain the PMM.
Regards
ankurjain1992
Post by ankurjain1992 » Wed Aug 05, 2020 5:50 am
Thanks for the reply...
I tried what you said but still getting difficulty.
Can you help sharing the STKO file for the PMM interaction curve.
Clarabella
Post by Clarabella » Wed Aug 05, 2020 7:22 am
Unfortunately the python file is not ready yet, however as we explained above, you just have to develop a series of simple analyses with P variable.
Best regards
ankurjain1992
Post by ankurjain1992 » Wed Aug 05, 2020 10:49 am
ok I will try to do that....Also kindly post the python file whenever it is ready....
Thanks in advance.
rrodriguez
Post by rrodriguez » Thu Jan 28, 2021 3:03 am
Has the feature been implemented in version 1.1.5 and is there a short tutorial on how to create a P-M diagram for a prestressed column/pile element?
Post by STKO Team » Fri Jan 29, 2021 9:15 am
Not yet, but we are working on it.
