The work tree and command bar is missing from the Preprocessor window.
It happened when I switched to the post-processor window and I deleted the work tree & command line of the Preprocessor window appeared in the Postprocessor window.
The screenshot is attached here.
How to add work tree and command bar in pre-processor window
- prepro.png (74.46 KiB) Viewed 2910 times
Re: How to add work tree and command bar in pre-processor window
Hi Asad,
In order to get your worktree and command line (I assume by command line, you mean terminal window)back, all you need to do is right click in a blank part of the main toolbar. This will open an editor panel. In that panel simply click to select the features you want to view.
I hope this helps!
I hope this helps!
More than thanks
