Rigid connection
Rigid connection
How can I make the two parts of the beam just connected? Right now, because they have become two separate sections, the load-bearing capacity has decreased.
- 2026.1.13 14.14zemgsheputong.rar
- (104.62 KiB) Downloaded 28 times
Re: Rigid connection
Sorry but I don't understand your issue. Your model is already attached into a single wire
Compared to the model below, the load-bearing capacity of the model above has decreased significantly.
- 2026.1.13.rar
- (101.11 KiB) Downloaded 13 times
My goal was to add reinforcement to certain areas of the beam, so I divided them into two stages, but the result was even lower than the load-bearing capacity without reinforcement.
