Hi STKO team
Further to my previous query, I still find something funny in my model. I checked p-delta, linear and corotational for, normal conditions and x10 exaggerated to see the p-delta sensitivity as previous.
1. I still have p-delta effect initially smaller than not considering it but in the end ramping up significantly. I have increased column load by 10.
- roofqd.PNG (40.02 KiB) Viewed 2732 times
2. I am aware that p delta leaning columns are squashed significantly. My understanding is that these are connected with rigid diaphragms in x and y direction but free to move z directions. Will the p-delta transformation effect be effective from the deflected shape under gravity loading in OpenSees ? In my exaggerated x10 load condition, the column is squashed 2m at the top. I can easily specify larger section, but have been avoiding it try not to attract moment between rigid diaphragms. I am pushing to 20 inches at roof COM, which is only 3.3 % and the column axial load is still under compression.
- colaxial.PNG (932.19 KiB) Viewed 2732 times
3. Ideally I want to have these p-delta columns pin connected, but whatever way I tried to pin them via below(high lighted in yellow), the model does not appear to run. I have been modifying the flexural stiffness modifier to really small number so that significant moment will not be attracted. Is there a clean way of having full pin connection to the diaphragm ?
- pdcol_prop.PNG (21.7 KiB) Viewed 2732 times
The model can be downloaded from below.
Your input would be much appreciated.
