I wonder whether the tcl files (including main.tcl) genareted by STKO program can run under Openseesmp program located at the Design-Safe Plaform or not.
Because, as it is known, Openseesmp program located at the Design-Safe Plaform only runs for the linux system.
I can not completely sure about this dilemma.
If anybody has an experience about this topic, may I get an information?
Openseesmp and Design-Safe Plaform
Best wishings,
Re: Openseesmp and Design-Safe Plaform
Look at our very first webinar.
I carefully consider your webinar material. I found some traces in the past events of DesignSafe. However, at the current time, it contains only OpenseesMP and OpenseesSP in its digital platform.
In this regrad, I try to run my simple Opensees codes which are obtained in way of being genrerated by STKO.
But, I can not obtain any files with an extension of "*.mpco". It is resulted with errors (See DesginSafe_For_Forum.PNG)
However, these codes are sucesfully run in DOS command system as "openseesmp.bat main.tcl 2" (see OpensesMP_For_Forum.PNG)
What must I do?
What must I do?
- OpensesMP_For_Forum.PNG (71.16 KiB) Viewed 2696 times
- DesignSafe_For_Forum.PNG (102.62 KiB) Viewed 2696 times
Best wishings,
Since I can not receive any reply, I wrote "https://www.designsafe-ci.org/". They suggest me to contact with you in order to control against any incompatibility for the current version of OpenseesMP (v3.7.0) which is currently embedded in the platform of Designsafe.
When I check the version of OpenseesMP under "OpenSees-Solvers" which is utilized by STKO, I can see that its version is v3.4.0.
However, I do not know the reason behind the failing of correctly running the Opensees files generated by STKO under OpenseesMP (v3.7.0) which belongs to the platform of Designsafe.
I sent you a typical output generated by the platform of Designsafe (see tapisjob.rar).
This matter is really important for me in order to sucessufully run the models with the finer-meshed of solid elements.
I look forward your reply, impatiently
- tapisjob.rar
- (1.09 KiB) Downloaded 143 times
Best wishings,
WARNING AnalysisMode::getGroupGraph - 0 vertices, has the Domain been populated?Are you sure you partitioned the model in STKO with the same number of processors you are using on DesignSafe?
