Shear Visualization
Posted: Sun Dec 01, 2019 5:51 pm
by GianmarcoManzo
Hi all,
How can I visualize the shear on the element? With section.force I can see only Axial, bending moment and torque moment
thx
Re: Shear Visualization
Posted: Mon Dec 02, 2019 10:02 am
by MassimoPetracca
Hi Gianmarco,
If you want to visualize the shear component at the section level, you should include the shear in the section description:
Before you created a fiber section and you directly used that in the special_purpose.BeamSectionProperty. In this way the section can only describe P-My-Mz.
What you should do instead is to use the sectionAggregator. there you can use the fiber section for the P-My-Mz components and you can explicitly use a uniaxial material (either elastic or not) for the shear and torsion components.
Let me know if you have any issue using the section aggregator
Posted: Mon Dec 02, 2019 6:17 pm
by GianmarcoManzo
OK. I have tried tu use section integrator. I have created in order:
- material
- fiber section
- section aggregator
- special purpose.beam.section.proprety in witch I have set the section aggregator tag
I have assigned to the element and at last I have created force.beam.column element. Is it correct?
Posted: Mon Dec 02, 2019 6:24 pm
by MassimoPetracca
Yes, those are the steps in the correct order.
As you noticed, when you use a fiber section in the aggregator, the P-Mx-My components are coupled (due to the fiber section). On the contrary, the shear components are uncoupled from each other and from other (P-Mx-My) components, since they are simple uniaxial models.
