Reg! Model compatibility issue while reading the stress and deformation profile
Posted: Tue Jun 16, 2026 2:04 pm
I am trying to model an arch. My model units are in mm, and I have applied an acceleration of 0.74 g as a body force according to the required loading condition. After running the analysis, I obtained the stress and displacement/deformation results attached with this email. But I am facing a few difficulties in interpreting the results:
Could you please check whether the stress distribution (stress profile) and displacement profile appears reasonable, and correct?
When I increase the deformation scale factor in the post-processing view, the model appears distorted and it seems to be a compatibility issue. Could you please explain:
What is this called?
Whether it indicates a problem with the model or is simply a visualization effect?
Is the overall model setup correct based on the applied body force and boundary conditions?
Are there any modeling or meshing issues that could affect the accuracy of the results?
I have attached the model files and result screenshots.
