Non-bonded segment
junruli
Non-bonded segment
Post by junruli » Thu Jan 15, 2026 1:52 am
I am modeling a reinforced concrete beam-column joint and need to create an unbonded zone in a part of the beam, but I don't know how to establish it. If you have any advice, I would be grateful.
Re: Non-bonded segment
Post by STKO Team » Fri Jan 23, 2026 8:59 am
What do you mean by "unbonded zone" ?
junruli
Post by junruli » Mon Jan 26, 2026 6:08 am
Concrete is not in contact with the reinforcing steel.
junruli
Post by junruli » Mon Jan 26, 2026 6:12 am
junruli
Post by junruli » Tue Jan 27, 2026 3:18 am
It's about preventing the steel reinforcement and concrete from coming into contact in the middle area of the beam, but I don't know what to do.
2026.1.13 14.14zemgsheputong.rar
(104.62 KiB) Downloaded 24 times
Post by STKO Team » Tue Jan 27, 2026 9:02 am
In a beam model with fiber sections, the perfect bond between steel and concrete is assumed (plane sections remain plain).
If you want to use beam model then you should do something like this:
https://opensees.berkeley.edu/workshop/ ... ration.pdf
junruli
Post by junruli » Tue Jan 27, 2026 12:40 pm
I don't quite understand what you mean. What I mean is that steel bars in the circled area of the diagram are equipped with sleeve-like items to prevent contact with the concrete. Currently, I want to implement this idea in STKO, but I don't know how to proceed.
Post by kesavapraba » Wed Feb 11, 2026 9:44 am
Hi, You might do the followings:
1] Model the concrete part using solid (ASDConcrete3D)
2] bonded rebars as embedded dispBeamColumn element with slip (ASDEmbeddedRebarWithSlip) interface between concrete and rebar,
3] the unbonded steel rebars as displBeamColumn element but without any embedment or interface between concrete
