material tester error
A.Manan
Post by A.Manan » Sat Dec 20, 2025 8:26 pm
i am modeling a masonry wall. i assigned damageTC3D property. while i run the tester material, this is the error i am having
Error:
Traceback (most recent call last):
File "C:\Program Files/STKO\external_solvers\opensees\physical_properties\utils\tester\TesterND.py", line 807, in onTestClicked
self.tester.run()
File "C:\Program Files/STKO\external_solvers\opensees\physical_properties\utils\tester\TesterND.py", line 274, in run
os.remove(temp_output_file)
FileNotFoundError: [WinError 2] The system cannot find the file specified: 'C:/Users/LAPTOP/AppData/Local/ASDEA Software Technology/STKO/TesterND/output.txt'
looking forward to your help.
thanks
A.Manan
Re: material tester error
Post by A.Manan » Sun Dec 21, 2025 9:43 pm
i am attaching my model. have a look at it
conventional_macro.rar
(122.4 KiB) Downloaded 22 times
Post by STKO Team » Tue Jan 27, 2026 9:05 am
In your model I don't see the DamageTC3D, you are using the ASDConcrete3D (which is fine. it's the updated version of it).
However i dont' have any error in the material tester. So maybe you are using an older version of OpenSees
