vertical earthquake analysis
ymuaamar1@gmail.com
Post by ymuaamar1@gmail.com » Sat Nov 15, 2025 10:55 am
hello dear, i am working on the effective of vertical earthquake and i am modeling the soil the problem is the input and output at base not the same i try to reduce mesh, but same things, can you help me to solve this?
soıl vertıcal.rar
(81.61 MiB) Downloaded 8 times
Re: vertical earthquake analysis
Post by STKO Team » Mon Nov 17, 2025 3:07 pm
First I noticed some oscillation in your monitor.
Don't use TRBF2 integrator with algorithms that do not update the tangent everytime. Change it to newmark.
Then, please explain better what is not equal.
ymuaamar1@gmail.com
Post by ymuaamar1@gmail.com » Sat Nov 22, 2025 6:44 pm
Thank you for the feedback.
Regarding the issue: I noticed that the input acceleration at the base and the output (recorded) acceleration at the same location are not identical. My understanding is that for a correct implementation of the boundary conditions, the input motion and the response at the base node should match. Could you please clarify if this expectation is correct? If not, what differences are normally expected?
Also, I would appreciate guidance on how to include the third (vertical) component of the earthquake in my analysis. Right now I am only applying the two horizontal components, and I want to make sure I implement the vertical one correctly in OpenSees.
ymuaamar1@gmail.com
Post by ymuaamar1@gmail.com » Mon Dec 01, 2025 12:33 pm
i fixed the soil now i have the compilate model for SPSS, but i have problem with the vertical displacement is zero can you help me to find the mistake
mseseervv.rar
(30.44 MiB) Downloaded 2 times
