Coupling wall/coating in diagonal compression test
Posted: Mon Nov 03, 2025 11:32 pm
Dear STKO staff, dear Colleagues,
I am working on the modelling of a wall strengthened with a fiber-reinforced mortar. To avoid excessive computation time, I decided to work in 2D using 2D faces and model "Damage TC3D".
With this approach, I obtained satisfactory results for the configuration without the coating.
For the strengthened configuration, I used the same base model and added two additional layers on both sides, placed 20 mm away from the wall. I introduced the equaldof constraint, assigning the wall as the master and the coating layers as the slaves. Although this modelling choice seems reasonable from a mechanical point of view, the results are clearly incorrect. The stiffness of the wall + coating system not only appears excessively high, but also shows no sensitivity to the coating input parameters.
Attached below some pictures of the one-side strenghtened wall and the load-deflection curve (the background plot refers to the unstrengthened configuration).
I look forward to your kind support.
