rror when using zeroLengthSection and zeroLength elements for segment joint modeling
Posted: Fri Sep 12, 2025 3:49 am
Dear STKO Support Team,
I built a numerical model of two tunnel segments using shell elements. To simulate the segment joints:
I used zeroLengthSection elements to represent the compression behavior of the joints.
I used zeroLength elements with uniaxialMaterial to represent the bolts in the joints, considering their tensile and shear behavior.
However, when I run the analysis, I encounter the following error:
MPCORecorder FATAL Error: trial_fiberdata.size() != trial_sec_id.size()
I strongly suspect the issue is related to my setup of the zeroLengthSection element and the zeroLength elements for the bolts, but I cannot identify the exact cause. Could you please help me check whether my modeling approach is correct, and why this error might occur?
Thank you very much for your support.
