Inquiry Regarding Analysis Errors in STKO
Seon-Hoon, Kim
Post by Seon-Hoon, Kim » Sat Aug 16, 2025 5:08 pm
My name is Seon-Hoon Kim, and I am currently pursuing a Ph.D. degree in Korea.
I have been actively utilizing STKO to conduct various numerical analyses, primarily focusing on beam-column connections. However, I have continuously encountered errors during the analyses. Accordingly, I am sharing the TCL and SCD files for your review. I kindly request your assistance in identifying the cause of these errors and providing a possible solution.
I would also appreciate it if you could share your response to the following email address once the review has been completed: [[email protected]].
Thank you very much for your support.
Sincerely,
Seon-Hoon Kim
Inquiry Regarding Analysis Errors in STKO.zip
(1.41 MiB) Downloaded 224 times
Re: Inquiry Regarding Analysis Errors in STKO
Post by STKO Team » Mon Aug 25, 2025 9:57 am
First I would not use Lagrange Multipliers as constraint handler.
Second, your model is failing in the second (Axial) analysis, which is a LoadControl analysis. Are you sure your model can sustain the imposed load?
