stress-strain response of confined Concrete issue
Posted: Sat Jun 21, 2025 6:05 am
by Tharuki
I am working on a high rise building. I get a wrong stress strain response for confined concrete once I defined the RectangularFiberSection for the column. Can you help me with this issue? I have attached the file.
Thank you in advance!
Re: stress-strain response of confined Concrete issue
Posted: Tue Jun 24, 2025 8:26 am
Posted: Tue Jun 24, 2025 10:14 am
by Tharuki
I have already replaced those files. However the same error is occuring. Also this error is occuring when I run the model.
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 1
Reducing increment factor due to non convergence. Factor = 0.5
WARNING: numeric analysis returns 1 -- Umfpackgenlinsolver::solve
WARNING NewtonLineSearch::solveCurrentStep() -the LinearSysOfEqn failed in solve()
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 0.5
Reducing increment factor due to non convergence. Factor = 0.25
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 0.25
Reducing increment factor due to non convergence. Factor = 0.125
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 0.125
Reducing increment factor due to non convergence. Factor = 0.0625
Can you please help me to solve this problem. I have attached the model here.
Posted: Fri Jun 27, 2025 8:14 am
Now the error is different: you are using positive values for concrete strain and negative values for stresses. While OpenSees now converts all of them to negative values, the Automatic Confinement tool expects those values to be ALL NEGATIVE. Just make them negative
This error instead is due to a singularity. From a quick check of your model I can see that the last 7 geometries in your model are not connected to anything. Double check your model
