Unbalanced reaction with the ForceFromReaction function
Posted: Fri Apr 18, 2025 6:16 am
Dear Support,
I can't get how to use the force from reaction function.
The problem is that there is some umbalced force that makes the model move.
In particular this happens when the initialization phase is solved in transient mode.
No problem with the static mode.
I need only to remove the fixes in x direction and replace them with forces in the dynamic phase.
The only difference in comparison with the advanced tutorial about an SSI case is that I have 2 soil layers and the domain is composed by some merged surface.
Can you kindly tell me how to use it and why does the model move itself ?
I annex the simple model of a slope in which I wanted to verify the problem.
In the following image is shown the u_x displacement and it can be seen that there is a cumulated, uncontrolled x displacement.
another important effect is that by following the resolving procedure used in the file annexed I have the same effect using the ASDAbsorbingElement2D auto.
Unfortunately, because of the up element I can't initialize the model with a static analysis.
Thanks in advance
Thanks in advance
