Wall-Soil interaction problem with contact2D and PressureDependMultiYield material
ziyanh
Post by ziyanh » Tue Mar 25, 2025 9:47 am
Dear STKO
I am trying to improve the pseudo-static wall-soil model I posted before with PressureDependMultiYield02 material in order to capture the accumulation of earth pressure during every two constant wall displacements. I have some problems with the model.
After applying 5 cyclic displacements, when the moveable wall is pulled away from the backfill, the soil element always starts failing and intrudes into the wall element. And a small part of the soil element is in tension, which is unrealistic. This makes the model harder to converge. Is it a problem with the contact2D interface or the PressureDependMultiYield02 material?
I attach the model here. What do you think I am doing wrong? Looking forward to your suggestions.
1311.rar
(143.96 KiB) Downloaded 97 times
Best regards
Ziyan
Re: Wall-Soil interaction problem with contact2D and PressureDependMultiYield material
Post by STKO Team » Thu Apr 10, 2025 10:47 am
Can you try if it works with an elastic material for the soil?
