Open multiple databases at once
Posted: Sat Mar 15, 2025 8:02 pm
by ragopesa
Hi STKO team,
I hope verything is going well.
I was hoping you can guide me. I would like to open multiple databases at once. Since I run many analysis, I'm experience several time to extract the result. I tried this:
import os
import itertools
from concurrent.futures import ProcessPoolExecutor
from time import sleep
import importlib
import ThreadUtils
importlib.reload(ThreadUtils)
import ThreadUtils as tu
from PySide2.QtCore import Qt, QObject, Signal, Slot, QThread,QEventLoop
from PySide2.QtWidgets import QMessageBox, QApplication
from PyMpc import *
import shutil
import glob
import multiprocessing
import numpy
from PySide2.QtWidgets import (
	QApplication,
	QDialog,
	QVBoxLayout,
	QProgressBar,
	QLabel,
	QListWidget,
	QListWidgetItem,
	QDialogButtonBox,
	QMessageBox,
	QInputDialog,
	QFileDialog,
def files_(inifile):
	out = []
	for i in inifile:
		values = [os.path.join(i,j) for j in os.listdir(i)]
		out.append(values)
	output = sum(out, [])
	return output
#Limpiar terminal
App.clearTerminal()
doc = App.postDocument()
#### Datos de entrada
name_1 = 'rotation_outputs'
name_2 = 'rotation_sp_stko.txt'
ini_path       = r'D:\rocking_\1._0.05\3._12levels\Active_Shallow'
folders_ni     = [os.path.join(ini_path,i) for i in os.listdir(ini_path) if os.path.isdir(os.path.join(ini_path, i))]
fullpaths      = files_(folders_ni)
files          = []
db_id_to_close = []
for jindex,jitem in enumerate(fullpaths):
	os.chdir(jitem)
	for fileitem in glob.glob("*.mpco"):
		location = jitem + '\\' + fileitem
		files.append(location)
def open_database(filename):
    """Función que abre la base de datos"""
    App.runCommand('OpenDatabase', filename)
def Parallel_Analysis():
	with ProcessPoolExecutor() as executor:
		### submit all tasks
		for parameter in files:
			p = executor.submit(open_database,parameter)
if __name__ == '__main__':
    Parallel_Analysis()
This is just part of the code. The issue is that, when I run it, it actually opens multiple STKO windows, instead of openning only the databases. My idea is to open all the databases and the postprocessing. Could you please help me?
All the best,
Salvador
Re: Open multiple databases at once
Posted: Tue Mar 18, 2025 1:14 pm
by ragopesa
Hi STKO team!!!
Best
Salvador
Posted: Fri Mar 21, 2025 7:11 am
by ragopesa
Hi STKO team!!
Could you please help me ?
All the best
Salvador
Posted: Wed Apr 02, 2025 7:54 am
You cannot use a ProcessPoolExecutor like that. It does some tricks behind the scene that causes multiple instances of the python interpreter to be open (and in our case the interpreter is embedded inside STKO).
