Error window: local variable xobj referenced before assignment
aziz_barzuk
Post by aziz_barzuk » Wed Feb 05, 2025 9:19 am
Unfortunately, during the steps after the mesh generation with linear quad elements, I get this error when I try to launch the analysis:
https://ibb.co/nNchxXrW
From a first sight seems that some element miss the physical properties. But I gave it to all elements before.
I noted that the error depends from the element chosen that in this case is the quadUP.
But If I change geometry with a more simple one, all is good.
This is the mesh I try to model and seems that all the elements are linked in the right way:
https://ibb.co/bgjkZFsn
I tried to constrain the mesh by slicing the domain before to perform the mesh, but this error I get is quite strange.
Another error I get is about the number or the type of element.
What is the correct and the best way to import a domain from cad (i.e. in iges format) ?
Is there a correct procedure to follow ?
Thanks in advance.
Re: Error window: local variable xobj referenced before assignment
Post by STKO Team » Wed Feb 05, 2025 3:26 pm
Yes this means that you did not assign a physical property on a sub-geometry where you have that physical property.
Without the model I cannot tell where it is
aziz_barzuk
Post by aziz_barzuk » Thu Feb 06, 2025 12:55 pm
Ok, thank you.
I solved, probably the problem was about the selection method.
But it would be nice to know something about the best way to import a user defined geometry arranged with a cad o something else.
Thanks.
Post by STKO Team » Thu Feb 06, 2025 1:36 pm
There is the Import command, it accepts STEP IGES or BREP
