running Openseesmp under "DOS Command System"
Posted: Tue Feb 04, 2025 2:45 pm
by MusZip
I strive to use the generated STKO files directly for Openseesmp under under "DOS Coomand System", not STKO enviroment.
For this purpose
I copied the all the generated STKO files into the directory "C:\OpenSees-Solvers"
Then, I activated the "DOS Coomand System" . The following outcomes from trials are obtaned.
i)"RUNNING AS SEQUENTIAL":
I can sucesfully run Openseesmp under "DOS Coomand System" with a solely command as "Openseesmp". Then, of Course, it can be defined the further "Opensees commands". This is not problem.
ii)"RUNNING AS PARALLEL":
I can not sucesfully run Openseesmp under "DOS Coomand System" with a command set
as "openseesmp.bat main.tcl 2"
I have an error as:
0 [main] mpiexec.hydra 8144 cygwin_exception::open_stackdumpfile: Dumping stack trace to mpiexec.hydra.exe.stackdump
iii)"RUNNING AS PARALLEL":
I can not sucesfully run Openseesmp under "DOS Coomand System" without using the ""openseesmp.bat"
as "mpiexec.hydra.exe -n 2 OpenSeesMP.exe main.tcl"
I have an error as:
0 [main] mpiexec.hydra 5672 cygwin_exception::open_stackdumpfile: Dumping stack trace to mpiexec.hydra.exe.stackdump
What must I do to deal with this problem arisen from the use of Openseesmp?
Re: running Openseesmp under "DOS Command System"
Posted: Thu Feb 06, 2025 8:59 am
First you don't need to copy those files in there (it's bad practice).
  • Keep your file in a directory (say C:\Analyses\Analysis1)
  • open a command line (cmd)
  • go into the analysis directory
    cd C:\Analyses\Analysis1
  • Run openseesmp with the same number of processors as the number of partitions in STKO mesh (let's say you partitioned it in 3 partitions)
    openseesmp.bat main.tcl 3
