Self-Weight of AbsorbingBoundary3D
Posted: Wed Jan 15, 2025 11:13 am
by Satoru
I am performing a 3DFE analysis of nonlinear (UCSD) soil with AbsorbingBoundary, and I find that when I perform the analysis with AbsorbingBoundary, the confining pressure of the soil domain is not calculated as I would expect in gravity analysis, and I assume that the value of stress does not include the self-weight of the AbsorbingBoudary.
In this analysis, I performed the gravity analysis by setting the self-weight in $b3 in the Brick Element option.
Could you please teach me how to properly account for the self-weight of the AbsorbingBoundary in gravity analysis?
If there is a way to properly account for the self-weight of AbsorbingBoundary, I would be happy to share a sample data.
Best Regards,
Re: Self-Weight of AbsorbingBoundary3D
Posted: Thu Jan 16, 2025 4:36 pm
Can you share a sample model?
Posted: Fri Jan 17, 2025 1:39 am
by Satoru
I created a sample data with AbsoringBoundary and without AbsoribingBoundary of gravity analysis. Please check the sample below.
FF1Brick_fix.zip
(95.89 KiB) Downloaded 148 times
FF1Brick_abs.zip
(86.59 KiB) Downloaded 150 times
Posted: Wed Jan 22, 2025 2:59 pm
... I assume that the value of stress does not include the self-weight of the AbsorbingBoudary ...
You are right, this is the difference between your 2 models.
As I explained in your previous post (viewtopic.php?p=9959#p9959):
Drawbacks in the current implementation:
Works only for the 3D version, not for the 2D one.
The FF columns now need the same self-weight (if any) given to the inner soil domain. Therefore you cannot use the ASDAbsorbingBoundary3DAuto, but you have to use the manual version (ASDAbsorbingBoundary3D), in this way, you have the extrusions of the absorbing layers on which you can apply the selfweight. On the contrary, the ASDAbsorbingBoundary3DAuto extrudes the absorbing layer "on the fly" when STKO runs the analysis. We need automation to make it work with the Auto version
We just finished implementing the above-mentioned automation. It will be available for everyone in the next STKO release 4.0.1.
In the meantime, you can:
  • Unzip this python file
    ASDAbsorbingBoundary3DSelfWeight.zip
    (2.54 KiB) Downloaded 108 times
    in C:\Develop\STKO\external_solvers\opensees\conditions\Loads\Force
    ASDAbsorbingBoundary3DAuto.zip
    (7.1 KiB) Downloaded 111 times
    in C:\Develop\STKO\external_solvers\opensees\element_properties\absorbingBoundaries, and replace the existing one
This is how you can implement it in your file:
FF1Brick_abs.zip
(91.49 KiB) Downloaded 126 times
You need to create the condition without assigning it to anything. It will automatically apply the self-weight to all absorbing boundaries generated via the ASDAbsorbingBoundary3DAuto condition.
Of course you need to put it in a pattern to include it in the opensees analysis.
Let us know if it works or if you have any doubts
Posted: Fri Jan 24, 2025 2:49 am
by Satoru
Thank you for your response and sending data.
I saved the python file and tried the method you showed me, but the error window in the URL below was launched when Write Input File. Do you know what the problem is?
https://www.dropbox.com/scl/fi/9abkczy1 ... jk4sg&dl=0
I also have a couple of questions.
1. Is it possible to give different self-weights to several AbsorbingBoundarys? I think this method gives a same self-weight to all Absorbing Boundarys.
2. Is it possible to set different self-weight for different Absorbing Boundarys in STKO Ver. 4.0.1? We plan to perform analysis with several layers of ground in the future, so it would be great if this functionality is provided.
3. When is STKO Ver. 4.0.1 to be available?
Posted: Mon Jan 27, 2025 8:50 am
This error means you only installed the ASDAbsorbingBoundary3DSelfWeight.py file, but you did not override the other ASDAbsorbingBoundary3DAuto.py replacing the existing one.
You are right, in this way it will assign the same to all absorbing boundaries.
Try to test it now with a uniform layer. In the meantime I will change the code so that in the ASDAbsorbingBoundary3DSelfWeight.py you assign the gravity acceleration vector. Then the code will assign, to each absorbing element, a self weight based on the g vector and the mass density from the absorbing material. Does it sound good for you?
I think I'll be able to provide you with the updated file between today and tomorrow
Posted: Tue Jan 28, 2025 1:05 am
by Satoru
The analysis of one brick element I received worked fine! The problem seemed to be that the old python file was renamed and still existed in the same folder.
I will check the results in a series of gravity to dynamic analyses to see if it works correctly.
As you say, it would be great if you could set the load due to gravity based on the mass density of AbsorbingBounday element.
Posted: Wed Feb 05, 2025 10:21 am
Update with these new files:
(1.6 KiB) Downloaded 127 times
(7.35 KiB) Downloaded 127 times
In the self-weight now b is the gravity acceleration vector, and will be multiplier by the rho of the absorbing material while computing the self weight load.
Let me know if you encounter any issue
Posted: Tue Feb 18, 2025 4:16 am
by Satoru
Thank you for your response!
I performed the analysis using the python file you created and got the response I expected.
I will contact you again if I need any further assistance!
Posted: Tue Feb 18, 2025 11:38 am
