AbsorbingBoundary3DAuto
Posted: Tue Dec 10, 2024 2:50 am
I am performing a non-linear SSI analysis considering soil nonlinearity, and I have the following questions about AbsorbingBoundary3DAuto.
1 : Can AbdoringBoundary3DAuto calculate non-linear free ground response? Checking STKO, the default method is to specify elastic parameters (G, ν, ρ), so it seems that AbdoringBoundary3DAuto can't consider nonlinearity of the free field. But if I set a non-linear material tag, is it possible to calcurate non-linear free ground response? It says UNDER BETA TESTING, when will it be available?
2 : When performing 1D ground response analysis, the sides of AbsorbingBoundary are not needed. So, Is it possible to apply AbsorbingBoundary3DAuto only to the bottom for the purpose of performing a nonlinear ground response analysis with input as 2E? If there is any other manual way, please let me know if there are any webinars etc.
Best Regards,
Best Regards,
