Failure to run analysis
Posted: Mon Nov 18, 2024 2:13 pm
by shiRo
I am trying to build a complete bridge, adding bearings and beams on the basis of the original piers. I refer to the modeling methods that have been used in the forum, using zero-length elements to simulate bearings and using elastic elements to simulate beams, but they cannot run successfully. From the given error report, it may be that there is an error in the zero-length . Can you help me check the model ?
best wishes!
Re: Failure to run analysis
Posted: Tue Nov 19, 2024 2:15 am
by shiRo
Supplementary explanation : I ignore the properties of the zero length unit, and there is no longer a prompt error after changing the ' 2D ' to ' 3D ', but there is still a convergence problem.
Posted: Tue Nov 26, 2024 9:30 am
Issues:
  • The fiber section for the Deck does not have -GJ (torsional stiffness) -> force beam element cannot invert flexibility matrix
  • One of the piers is missing fixities
  • Deck fiber section does not have steel, and its concrete has zero tensile strength -> cannot invert flexibility as nothing is reacting in tension
  • The zeroLength elements (springs) at the 2 extremities of the Deck are discretized in 2 elements each one -> singularity (use only 1 mesh per spring)
  • The zeroLength elements (springs) at the 2 extremities of the Deck are missing materials in the local Y Z rotational DOFs. Without those the deck are some rigid body rotations
