Page 1 of 2
Property assignment
Posted: Wed Nov 06, 2024 2:54 am
by BrownTrout_NZ
Hi STKO team
I have been trying to create STKO model using Python API and managed to create all B-reps and some condition assignments (such as support conditions, loads & diaphragms) but have a couple of questions.
1. I have set up faces in the model and named "W1", "W2" etc expecting that I am able to assign certain wall property to them. I have created below code, but it will report that the face number is 0 in the terminal and does not recognize face property. Can you please provide some sample code example for this?
snip face.PNG (59.39 KiB) Viewed 2686 times
2. I want to know how to create selection set, please provide sample codes.
3. Also assign element & material below do not appear to work. No error messages, but it just does not work. Please assist on this.
4. Lastly please provide some codes to control mesh. For walls I want to split them in 3 layers / storey horizontally for SFI-MVLEM element(no vertical meshing).
CREATE_STKO_MODEL_TW1_MANUAL.zip
(7.75 KiB) Downloaded 83 times
Hope to hear from you soon.
Re: Property assignment
Posted: Tue Nov 12, 2024 3:06 am
by BrownTrout_NZ
Also, below code does not appear to work and have issues with passing quantityevectors. Can someone form STKO team please let me know what I am missing.
def makeSFI_MVLEM_ADD (id, m, Thicknesses, Widths, Material_tags, CoR, c, ThickMod, tMod, Poisson, Nu, Density, Dens, name):
	meta_ele = doc.metaDataElementProperty('beam_column_elements.SFI_MVLEM_3D')
	xobj_ele = MpcXObject.createInstanceOf(meta_ele)
	xobj_ele.getAttribute('m').integer = m
	xobj_ele.getAttribute('Thicknesses').quantityVector = Thicknesses
	xobj_ele.getAttribute('Widths').quantityVector = Widths
	xobj_ele.getAttribute('Material_tags').indexVector = Material_tags
	xobj_ele.getAttribute('-CoR').Boolean = CoR
	xobj_ele.getAttribute('c').quantityScalar = c
	xobj_ele.getAttribute('-ThickMod').Boolean = ThickMod
	xobj_ele.getAttribute('tMod').quantityScalar = tMod
	xobj_ele.getAttribute('-Poisson').Boolean  = Poisson
	xobj_ele.getAttribute('Nu').quantityScalar = Nu
	xobj_ele.getAttribute('-Density').Boolean  = Density
	xobj_ele.getAttribute('Dens').quantityScalar = Dens
	prop = MpcProperty()
	prop.id = id
	prop.name = str(name)
	prop.XObject = xobj_ele
	doc.addElementProperty(prop)
	doc.commitChanges()
	doc.dirty = True
	prop.commitXObjectChanges()
TK = [0.2, 0.2, 0.2]
WID = [0.5, 0.5, 0.5]
MAT = [1, 2, 1]
makeSFI_MVLEM_ADD (151, 3, TK, WID, MAT, True, 0.02, True, 0.08, True, 0.7, True, 2.4, "MVLEM FROM API")
Posted: Wed Nov 13, 2024 10:45 am
Sub-geometries do not have a name, you can access them by their local index. For each type of sub-shape, the local index is continuous and zero-based.
# create a new selection set
sset_id = doc.selectionSets.getlastkey(0)+1
sset_name = 'Sample Set Whole Geometry'
sset = MpcSelectionSet(sset_id, sset_name)
# add geometries
# example 1) add the whole geometry with ID = 3
item_whole_geom_3 = MpcSelectionSetItem()
item_whole_geom_3.wholeGeometry = True
sset.geometries[3] = item_whole_geom_3
# add it to the document
doc.addSelectionSet(sset)
doc.commitChanges()
sset_name = 'Sample Set Only 1 Face'
# add geometries
# example 2) add only first face (id = 0) of geometry with ID = 3
item_geom_3_face_0 = MpcSelectionSetItem()
item_geom_3_face_0.wholeGeometry = False
item_geom_3_face_0.faces.append(0)
# in the same way you can append to vertices,edges,solids...
# just remember that subshapes have contiguous 0-based indexing
sset.geometries[3] = item_geom_3_face_0
doc.commitChanges()
This should work. Note that the selection in the graphic window only works for geometries that have been regenerated (i.e. they have graphical mesh for the graphical windows). Make sure that, if you assign a property to a geometry, you called Regen after the geometry has been added to the document
# setup global controls
geom_id = 3 # geometry with ID = 3
edge_id = 0 # the first edge of geometry 3
geom_controls = mc.geometryControls[3]
seed = MpcMeshEdgeSeed()
seed.type = MpcMeshEdgeSeedType.UniformByDivisions
seed.divisions = 20
geom_controls.edgeControls[edge_id].seed = seed
.quantityVector.value = ...
Posted: Thu Nov 14, 2024 5:16 am
by BrownTrout_NZ
Thanks STKO team ! It is all good except below.
Could you please assist me on this ? Much appreciated.
	xobj_ele.getAttribute('Thicknesses').quantityVector.value = Thicknesses
	xobj_ele.getAttribute('Widths').quantityVector.value = Widths
	xobj_ele.getAttribute('Material_tags').indexVector.value = Material_tags
	xobj_ele.getAttribute('c').quantityScalar.value = c
	xobj_ele.getAttribute('tMod').quantityScalar.value = tMod
	xobj_ele.getAttribute('Nu').quantityScalar.value = Nu
	xobj_ele.getAttribute('Dens').quantityScalar.value = Dens
	prop.id = id
	doc.commitChanges()
	doc.dirty = True
MAT = [1, 2, 1]
Posted: Thu Nov 14, 2024 9:13 am
You declared a physical property (prop = MpcProperty())
Instead you wanted an element property (prop = MpcElementProperty())
Posted: Thu Nov 14, 2024 5:05 pm
by BrownTrout_NZ
worked like a charm, THANK YOU !!
Posted: Fri Nov 15, 2024 7:50 pm
by BrownTrout_NZ
Sorry to bother you guys once again, but below code all works fine except for material tags without any error messages.
Material tag stays "None" regardless of the fact that material ids exist in the Model or not.
If I specify managerial id which does not exit, does not spit any error messages. Based on the py library for SFI-MVLEM(bottom snip), should this raise the error message?
Can you please let me know what I am missing here. Is there any syntax issues ?
	prop = MpcElementProperty() # 		CAREFUL !!
	prop.id = id
	doc.commitChanges()
	doc.dirty = True
#TK = [0.2, 0.2, 0.2]
#WID = [0.5, 0.5, 0.5]
#MAT = [1, 2, 1]
#makeSFI_MVLEM_ADD (151, 3, TK, WID, MAT, True, 0.02, True, 0.08, True, 0.7, True, 2.4, "MVLEM FROM API")
Posted: Mon Nov 18, 2024 2:36 am
by BrownTrout_NZ
Similarly below code will not put section from library as we do manually from drop down menu, please advise asap,
def makeSECTIONS_ADD (id, Dimension, Section, Use_Uniaxial_Materials, E, G, Optional, Izz_modifier, Iyy_modifier, Y, Z, name):
	meta_ele = doc.metaDataPhysicalProperty('sections.Elastic')
	xobj_ele.getAttribute('Dimension').string = str(Dimension)
	xobj_ele.getAttribute('3D').Boolean = True
	xobj_ele.getAttribute('2D').Boolean = False
	xobj_ele.getAttribute('Section').customAttributeObject = str(Section)
	xobj_ele.getAttribute('Use Uniaxial Materials').Boolean = Use_Uniaxial_Materials
	xobj_ele.getAttribute('E').quantityScalar.value = E
	xobj_ele.getAttribute('Em material').index = 10
	xobj_ele.getAttribute('Eb material').index = 10
	xobj_ele.getAttribute('G material').index = 10
	xobj_ele.getAttribute('G/3D').quantityScalar.value = G
	xobj_ele.getAttribute('Optional').Boolean = Optional
	xobj_ele.getAttribute('Izz_modifier').real = Izz_modifier
	xobj_ele.getAttribute('Iyy_modifier').real = Iyy_modifier
	xobj_ele.getAttribute('Y/section_offset').quantityScalar.value = Y
	xobj_ele.getAttribute('Z/section_offset').quantityScalar.value  = Z
	prop.id = id
	doc.addPhysicalProperty(prop)
	doc.commitChanges()
	doc.dirty = True
for attribute_name, attribute in xobj_ele.attributes.items():
	print('"{}" ({})'.format(attribute_name, attribute.type))
makeSECTIONS_ADD (40, "3D", "HSS 6x6x0.625", False, 205000000, 80000000, False, 1.0, 1.0, 0, 0, "SHS-SECTION")
Posted: Mon Nov 18, 2024 9:56 am
Don't use the attribute value in the indexVector:
Note that a quantityVector is something that support a value and unit system, that's why you have a .value attribute.
an indexVector is just an array of integers.
So why does Python let you do it without rasing an error saying that the attribute .value is not present in .indexVector?
Because in python you can inject new attributes an method in classes:
try this script:
class aClass:
	def __init__(self, value):
		self.value = value
x = aClass(3.0)
print('\nbefore method injection')
print('\n'.join(i for i in dir(x) if not i.startswith('__')))
print('\nafter method injection')
x.aNewValue = 111.0
