ASDConcrete3D use with brick element?
Posted: Wed Oct 23, 2024 8:31 am
by kolozvari
I am trying to model mat foundation as nonlinear and I am planning to use ASCEConcrete3D. Is it possible to use this material with brick elements? I see that all examples refer to layered shell element, but since this is a 3D model for concrete I thought it might be possible to use it with bricks. If so, do you have any examples?
Please let me know. Thank you
Re: ASDConcrete3D use with brick element?
Posted: Wed Oct 23, 2024 4:29 pm
Hi, yes. It is possible to use it with brick or tetrahedron element as the constitutive model is 3D. Personally, I used it for simulating punching shear in flat slab.
Posted: Wed Oct 23, 2024 7:45 pm
by kolozvari
Ok great thank you. In this case, how would you model the reinforcement? I suppose it needs to be modeled somehow explicitly where idnhave to model both shear and flexural reinforcement, which might become tricky for a big mat foundation. Can you please provide your thoughts?
Thanks
Posted: Thu Oct 24, 2024 9:03 am
Yes the only way is to model rebars as beam elements and to embed them inside the solid domain
Posted: Thu Oct 24, 2024 9:35 am
by kolozvari
Thanks. Do you have any examples on how to do that?
Posted: Fri Oct 25, 2024 8:16 am
The webinar about ASDEmbeddedNodeElement (#023 New Element Presentation- Embedding Rebars into Solid Domains)
Posted: Fri Oct 25, 2024 8:19 am
by kolozvari
Thank you!
Posted: Fri Oct 25, 2024 8:27 am
