I am using the following parameric recorder option from one of the other threads on the forum.
this is the error I am getting. Please advise - thanks!# PARAMETRIC RECORDER:
# this is a trick... when STKO writes the mpco recorder command, it also writes
# a support *.mpco.cdata file with the same name of the recorder. However in STKO the
# recorder name has a suffix = $param_id, that will be evaluated by TCL when creating the
# *.mpco file, but not at the time STKO writes the *.mpco.cdata file. So we can
# simply copy the one created by STKO and rename it accordingly.
# this is the name STKO gave it... make sure to use the escape character before the $ char!!
set STKO_file_name "SSI_\$param_id.part-$PID.mpco.cdata"; # OLD: with OpenSeesMP?
#set STKO_file_name "\$mpco_fname.mpco.cdata"
# this is the new name, DON'T use the escape character, to the param_id will be eval by TCL!
set current_file_name "SSI_$param_id.part-$PID.mpco.cdata"; # OLD: with OpenSeesMP?
#set current_file_name "$mpco_fname.mpco.cdata"
file copy -force $STKO_file_name $current_file_name
src\H5Fint.c line 2179 in H5F__flush_phase2(): prep for MDC flush failed
major: Object cache
minor: Unable to flush data from cache
#007: C:\J\w\prod\BuildSingleReference\.conan\data\hdf5\1.14.0\_\_\build\f491c24a6c1b13acb3cc68e656f08b3ca13fc643\src\srta\hdf5\1.14.0\_\_\build\f491c24a6c1b13acb3cc68e656f08b3ca13fc643\src\src\H5Fint.c line 2179 in H5F__flush_phase2(): prep for MDC flush failed
major: Object cache
#007: C:\J\w\prod\BuildSingleReference\.conan\data\hdf5\1.14.0\_\_\build\f491c24a6c1b13acb3cc68e656f08b3ca13fc643\src\src\H5AC.c line 1230 in H5AC_prep_for_file_flush(): slist enabled failed
major: Object cache
minor: Internal error detected
#008: C:\J\w\prod\BuildSingleReference\.conan\data\hdf5\1.14.0\_\_\build\f491c24a6c1b13acb3cc68e656f08b3ca13fc643\src\src\H5C.c line 2940 in H5C_set_slist_enabled(): slist already enabled?
major: Object cache
MPCORecorder Error: cannot flush file on record()
major: Object cache
major: Object cache
major: Object cache
Increment: 9 | Iterations: 6 | Norm: 8.570e-06 | Progress: 90.000 %
major: Object cache
major: Object cache
minor: Internal error detec\H5AC.c line 1230 in H5AC_prep_for_file_flush(): slist enabled failed
major: Object cache
#008: C:\J\w\prod\BuildSingleReference\.conan\data\hdf5\1.14.0\_\_\build\f491c24a6c1b13acb3cc68e656f08b3ca13fc643\src\src\H5C.c line 2940 in H5C_set_slist_enabled(): slist already encted
abled?
major: Object cache
