Interaction
Posted: Fri Aug 23, 2024 3:01 pm
Hello dear asdea team,
I need to model some stone columns in the soil profile containing 2 layers, Actually these columns are completely burried.
I modeled these columns in a completely different way than yours. Actually for creating them,
At first, I created 2 cubes as soil layers.
2-I drew cylinders into cubes (soil layers),
3- Using "subtract" command, I removed the cylinders from the soil and again filled removed cylinders.
I have some questions:
1)Is above procedure true for building the geometry of model?
2)As the columns are completely burried, Is it necessary to create 4 interactions for each columns (2 interactions for around and top the column in the first layer and 2 interactions for around and bottom the column in the second layer)?
3)As I understood from your pile group example, the interaction around the column with the soil should be of "node to element" type and the interaction of top and bottom of columns with the soils should be of " node to node" type?
For the interaction around columns I choosed "column "solid"" as master and "soil "face"" as slave,
For top and bottom, I choosed "face" of column and soil as master and slave,
Is this procedure true?
4) Finally, I feel the interaction that I built is not true. In your example the interaction of base has a different figure.
Thank you so much in advance
