Impact of the corotaional using ASDSHELL Q4 and ASD CONCRETE 3D
Posted: Tue Jul 02, 2024 8:06 pm
Dear STKO,
I would like to study the effect of geometric nonlinearity using corotational formula on the deflection of a slab loaded at the center of the span with a node force.
I created two models
1. elastic material (corotational or linear)
2. nonlinear material Stell 02 and Asd Concrete 3D making a shell element that is 200 mm thick and has top and bottom reinforcement in two directions.
The fibers are:
1. Concrete 30 mm
2, Stell #6 spaced 200 mm =0.14
3. Stell #6 spaced 200 mm =0.14
4. Concrete 136 mm
5, Stell #6 spaced 200 mm =0.14
6. Stell #6 spaced 200 mm =0.14
7. Concrete 30 mm
Should I include the diameter of the reinforcement in the total thickness of the shell ? Now the concrete itself has 196 mm.
I also wanted to make sure I understood defining the layers of the fiber element correctly. Assuming, for example, that the bottom reinforcement was #16 every 150 mm, would I have to change positions 5 and 6? When do we know if a particular layer is on top or bottom?
In the middle of the slab I created a control node in which I want to study the deflections depending on the increase of the concentrated force
1. In the first model i created a load control analysis at set the duration as my load factor. In the monitor i choosed pseudo time (it should simulate the increasing force) (the force at the control node is 1kN=1000N (my units are N/mm) 2. In model 2, I wanted to apply pushdown analysis using the displacement method. In the monitor i used the same settings. My problem is that I do not know how to interpret the results of what is happening to my model. Displacements are increasing as in elastic analysis. The crack plot shows ad the end cracks only in the middle, but in the step 17 its looks good. (why ??)
Next i have general questions for Asd 3D concrete model. I am mainly analyzing vertically loaded slabs, is this constitutive model suitable for this or do you recommend another approach? On webinars this model used in loads in the plane of shell elements. I want to make multi-story slab-and-column structures after previous attempts on small models. Won't using the ASD 3D concrete model result in too much computational requirements (costs)?
Best regards
The fibers are:
1. Concrete 30 mm
4. Concrete 136 mm
7. Concrete 30 mm
Best regards
