EqualDof and Rigid Links
Posted: Fri Jun 21, 2024 6:33 pm
I am trying to apply a master to slave nodes relationship between a single node (master) and many nodes at the same elevation level (slave) of continuum 8-node SSPbrickUP elements. I am aware of the EqualDOF command and the RigidLink command that might help with this. However, the information in the OpenSees manual does not provide a clear difference between these two commands.
I would like to ask, what is the difference between these two commands?
Also, if I set EqualDOF between master and slave nodes in the 1, 2, 3 (x, y, z) directions, is it equivalent to setting a RigidLink bar ($type) command?
Thanks for your your explanation and advice in advance.
Sincerely,
Ryan Chia
Sincerely,
Ryan Chia
