nDmaterials - ASDEASoftware / PlugIn
Posted: Fri May 17, 2024 12:06 pm
I am trying to apply the nDMaterial (ASDEASoftware / PlugIn) to simulate the masonry wall. Now, I am using the free unlimited 30-day trial of STKO, but when I perform the analysis, the following WARNING always occurs. Could you help me to fix it? Look forward for you reply.
Best regards!
Tao
Re: nDmaterials - ASDEASoftware / PlugIn
Posted: Fri May 17, 2024 2:06 pm
It's because you are using the official OpenSees version.
In that version, the maintainer didn't want to add our plugin. So if you want the DamageTC3D, you must use the unofficial version distributed by Prof. Tarque here:
https://www.pucp.edu.pe/profesor/sabino ... ducciones/,
otherwise you can use the ASDConcrete3D which instead is in the official version of OpenSees
Posted: Sat May 18, 2024 12:45 pm
Thank you very much! I have fixed the problem!
Posted: Mon May 20, 2024 8:42 am
Posted: Sat Dec 20, 2025 8:08 pm
by A.Manan
[email protected] wrote: ↑Sat May 18, 2024 12:45 pm
hi!
can you tell me how did you fixed it?
thanks
Posted: Thu Jan 22, 2026 9:00 am
Download the un-official version compiled by prof. Tarque
https://www.researchgate.net/publicatio ... ltext=true
