how to use MPCO Recorder in openseespy
Posted: Mon Jan 08, 2024 2:07 pm
by zxh
As is well known, we can use the MPCO Recorder to generate post-processing files and then perform post-processing using STKO. The TCL version of OpenSees can accomplish this with the MPCO Recorder. Now, my model is built using openseespy and I am unable to use the MPCO Recorder to generate post-processing files. How should I compile the MPCO Recorder into openseespy?
Re: how to use MPCO Recorder in openseespy
Posted: Fri Jan 12, 2024 9:00 am
Now MPCO Recorder is not compiled with openseespy because they don't want to include the HDF5 library it depends on.
We are planning to include it in openseespy without the need for linking to HDF5.
In the meantime, if you are able to compile openseespy by yourself, we can tell you how to include the mpco recoder there
Posted: Thu May 16, 2024 3:54 am
by nmorabowen
Is the hdf5 library compiled into professor Tarque's version?
If not, could you please tell me how this could be done?
Posted: Thu May 16, 2024 8:19 am
Yes, the MPCORecorder is included.
If you want to compile your own version of OpenSees and/or OpenSeesPy including the MPCORecorder, please follow the instruction here https://opensees.github.io/OpenSeesDocu ... build.html using CMake and Conan (this toolchain will take care of downloading all the necessary dependencies, including hdf5)
Posted: Thu May 16, 2024 4:04 pm
by nmorabowen
Thank you!
Posted: Fri May 17, 2024 8:32 am
Posted: Wed Aug 07, 2024 11:33 am
by OmarA
I have compiled openseespy following the instructions in the link. How can I include MPCO recorders?
Thanks in advance
Posted: Thu Aug 08, 2024 7:25 am
Just use the mpco recorder command in your file.
Documentation here:
https://drive.google.com/file/d/1V6Dh8C ... cIDBT/view
It's for Tcl but it's super easy to convert it to python
