Error:physical property must be sections and not special_puepose
Posted: Tue Jul 04, 2023 7:28 am
My model has an error as shown in the image, but I don't know exactly where this error is, because I still have an identical model that works. It would be great if you could check it out for me, thank you.
Re: Error:physical property must be sections and not special_puepose
Posted: Tue Jul 04, 2023 8:07 am
It's because you are using a DispBeamColumInt, try the dispbeamcolumn or forcebeamcolumn.
Posted: Wed Jul 05, 2023 9:42 am
Dear STKO Steam:
Thank you very much for your previous help, but I fixed it and got a new error, if you have time I would like to get your help again.
Posted: Fri Jul 07, 2023 7:12 am
by ValentinaSB
Can you please attach the model where you have this error? I tried to change the element properties in the model you attached before, and it works for me. (you also need to add a node to your selection set that you use for displacement control)
Valentina
Posted: Sat Jul 08, 2023 6:48 am
Thank you very much for your reply, this is my model, look forward to your help, it is important to me.
Posted: Mon Jul 10, 2023 8:21 am
It's because in your monitor you did not choose any selection set
Posted: Mon Jul 10, 2023 12:23 pm
Thank you very much for helping me find this error, but after I fixed this error, I found that it still does not work, I don't know what the error message in the figure means.
Posted: Mon Jul 17, 2023 10:26 am
It seems you set up your analysis for parallel computing with OpenSeesMP ( I can see it from the ParallelRCM numberer), but you lanched the sequential opensees that does not have that option.
Just use OpenSeesMP
