FATAL:second_order_eqn: Complex roots. when moving active surface.
Posted: Sun Mar 26, 2023 9:34 pm
by begumemte1991
Dear Team STKO,
What is the meaning of the following error:
"FATAL:second_order_eqn: Complex roots.
B2=8.34901e-23 4AC=9.37715e-23"?
NB: I am conducting a ground response analysis under seismic loading.
Re: FATAL:second_order_eqn: Complex roots. when moving active surface.
Posted: Tue Mar 28, 2023 4:44 pm
by ValentinaSB
This error means that OpenSees is not able to solve the second-order equation somewhere in the model, that B^2 - 4*A*C is negative. There are could be different reasons that could lead to this numerical problem, for example, improper input parameters. Make sure that the parameters that you are using are correct for the PDMY(PIMY)material.
Best wishes,
Valentina
