Potential bug with MVLEM_3D
kolozvari
Post by kolozvari » Sat Jan 14, 2023 8:44 pm
When I try to use "Density" optional parameter in MVLEM I receive this input in the MVLEM command, which will clearly create an issue. OpenSees excepts a double and receives a string.
element MVLEM_3D ........ -Density Dimension:
Please take a look and fix it in your next edition if necessary - hopefully soon.
Please let me know. Thanks,
Re: Potential bug with MVLEM_3D
Post by STKO Team » Mon Jan 16, 2023 7:47 am
Thank you for spotting this bug.
It will be fixed in the next release 3.2.1
In the meantime here are the modified files (the bug was in both MVLEM_3D and SFI_MVLEM_3D when using optional arguments):
SFI_MVLEM_and_MVLEM_3D_elements_bugfix.zip
(5.15 KiB) Downloaded 100 times
Unzip them and replace them in C:\Program Files\STKO\external_solvers\opensees\element_properties\beam_column_elements, replacing the existing ones.
Let us know
