Frame load high span ratio
I analyzed the concrete frame supported by the corner brace. When I analyzed the frame with the same height and different span, I found that his displacement load curve was not very different. I felt that it was a matter of self-weight, and I added a certain load but the difference was not obvious
- KF(4 6 8)- 10.rar
- (458.75 KiB) Downloaded 191 times
- jpg.zip
- (43.55 KiB) Downloaded 168 times
have a pattern
Re: Frame load high span ratio
The gravity load is not added to the loadPattern
I reloaded it and there's not much difference
- 纯框架 (4 6 8 ).rar
- (462.73 KiB) Downloaded 173 times
have a pattern
I don't understand what you are trying to compare. Two of them have no braces. They are not the same model.
However, probably changing only the span is not going to influence a lot the shear strength given by the same 2 columns
