STKO is closed automatically after the built meshing command is run.
One message appears in red: MASSIMO:block.
Thanks,
Stko is closed after meshing
- Meshing.JPG (111.52 KiB) Viewed 3282 times
Re: Stko is closed after meshing
Could you share your model?
It means that there is something wrong with the geometry and STKO cannot compute the Delaunay mesh
hello stko team,
the same thing happens with me as well. STKO is closing after building mesh. could you please help me out with this.
Thankyou
Thankyou
Please share your model, there is probably something wrong with your geometry
