Page 1 of 2
Why I cannot see the pile?
Posted: Mon Dec 13, 2021 3:48 am
by spater
I built the model step by step from your webinar video, but when I finished the analysis, I loaded the results, I only could see the line represented the pile. I assigned the section to the pile. What should I set in the postprocessor?
Re: Why I cannot see the pile?
Posted: Mon Dec 13, 2021 4:57 am
Make sure "show beam extrusion" is turned on in the surface plot options.
Posted: Mon Dec 13, 2021 6:53 am
by spater
I turned it on but it still invisible.
Posted: Mon Dec 13, 2021 8:38 am
If you created the model from the STKO pre-processor, and you used an MPCRecorder analysis step (not manually via TCL scripting" you should have a file with the same name of your mpco recorder, but with the mpco.cdata extension.
Can you verify you have it? otherwise the beam extrusion won't be visible.
Posted: Mon Dec 13, 2021 9:25 am
by spater
I downloaded this model from THE STKO website, I want to see the post processing module, but it just can't show the pile.
Can you help me to solve this problem?
It confused me very much.
Thank you!
Posted: Mon Dec 13, 2021 11:16 am
I know. Do you have the .mpco.cdata (the highlighted one) file in your directory?
Immagine 2021-12-13 121523.png (53.26 KiB) Viewed 3876 times
Posted: Mon Dec 13, 2021 12:49 pm
by spater
I don't have this file.
I found the description of the ".mpco.cdata" file in the STKO manual. But when I finished analysis, it didn't creat this file.
How can I deal with this problem?
Thank you very much.
Best reagrd!
Posted: Wed Dec 15, 2021 2:20 am
by spater
can you help me solve this problem? I really need to solve this problem
I hope you can reply to me as soon as possible. Thank you very much.
Posted: Wed Dec 15, 2021 8:53 am
Unfortunately, the file you attached is perfectly working on our side.
Are you sure you did not change anything in the file?
Can you show a screenshot of what files you have in the folder?
Posted: Wed Dec 15, 2021 9:20 am
by spater
I re-downloaded the file from the official website without making any changes, but it is still the same.
Eventhouht there exised a ***.mpco.cdata file, I still can only see one thread.
Attached is my operation screen recording, please help me solve this problem, I am really anxious.
Thank you very much!
