I have a problem with the mesh generation. In this beam I modeled the anchorage plate on each side of the element. The problem is that I need to generate a structurate quad mesh for the shell but on the right the program generates a mesh that is formed by one triangular and others rectangles while on the left I have only rectangular. The elements are the same.
I attached the model.
Thanks in advance
Antonella
Mesh problem
AntoMarinelli
Mesh problem
- H1500_FRC50_beam.rar
- (361.63 KiB) Downloaded 349 times
Re: Mesh problem
Hi AntoMarinelli,
I opened your model and I solved the issue by remodelling the anchorages plates. Here is the model!
Luis
Luis
baovietgps
Re: Mesh problem
Hi baovietgps,
can you attach your model so we can check out your problem?
